Abnormal Brake Pad Wear
I disassembled my front brakes today to investigate a brake squeal. I wanted to make sure the existing pads had enough material remaining until I'm ready to replace them with 100 series pads in conjunction with my front axle PM. What I found was one pad on my left front brake is wearing unevenly--its pie shaped. Other pads have even wear with about 4mm of material remaining. The left, or outer pad, on the driver's side has 4mm on the upper end (of caliper) slimming down to 1.5 - 2 mm on the bottom. Is this indicative of another problem, such as caliper piston problem? I want to make sure I have parts available and correct the problem when I do all the other front axle maintenance. Pics attached below.
Thanks...Mike
I would disagree...that sort of little uneven wear on what appears to be pretty shot pads could be due to the caliper slides being worn, sticky, or sure a piston sticking, but I doubt the latter most thought.
No matter what, new calipers, whatever, they never seem to wear perfectly evenly. If you listen to your parts guy at an Autozone he'll have you buying calipers, pads, antisqueal juice, et cetera. Please feel free to disagree with me but I'd just pop on new pads and be done with it when the time comes.
But if you do put on new calipers, I guarantee you will still not have perfectly even wear when you look at them after you've put on another 25k miles.
Are the slide pins corroded and "sticky"? I recently replaced mine due to a similar pad wear pattern. There is an inexpensive parts kit for the caliper which consists of a pair of slide pins and a spring clip.
I agree with Post 4 in essence. No huge problem here but new slider pins and lube is a great idea to help minimize it. If I took these off my truck I'd just slap new pads on when they were worn down. I wear mine down much, much thinner than this.
Also, bleed them as preventative to sticking pistons every other year at minimum.
DougM
Appreciate the inputs. The pins are a little corroded and dusty (like most brake parts). I'll probably just do the caliper rebuild while I have everything apart so I don't have to mess with the front end after the PM.
Thanks,
Mike
Another thought...
I can't remember if there are stainless steel sliders in the caliper mounts at the top and bottom of the pads. But if there is, be sure to remove them and take a wire brush to the surfaces directly underneath each slider to remove any rust buildup. The rust buildup will cause the dstance between each slider to decrease; causing friction at the end of the pad. Thus, uneven wear.
This was a frequent problem with the calipers on my '95 Maxima.
Something to keep in mind...
JSF
