AA SBC Rear Crossmember
I did an AA v8 swap about 12 years ago and have always had a problem with a leaking xfer case.
It seems that where the crossmember bolts to the xfer case you have to double gasket it between the xfer case and the tin piece that covers the trans shaft end.
My question is, is there a better way of doing this so that it will not leek?
So can this be installed easily without a body lift? I just finished a V8 swap in my 74 and decided to make my own because of alot of bad things that people have said about this design.
So is it improved over the previous design? :confused:
hijack over....:D
"improved" is relative....lol
IMO, the AA propellor design is flawed regardless....the distance down the frame between the motor mount points and the t-case mount points allows for more frame flex than this type of mount can handle. it "should" be a 3-point mount, with a center-type bushing to completely eliminate the twisting issues.
treerootCO did an EXCELLENT job with his design when he installed his Orion case....custom work, but not terribly difficult - see his writup linked off the 'MUD home page.
unfortunately that design is not an option for me using the short downey adapter from the 700r to LC tcase....
Not too much room between the two.
if you are mounting a 700R, then it has a pad under it for a stock-type mount...it's what I used for my D300 setup and you may be able to adapt the ideas for yours.
Hardcore corner, search "d300" and you should find the thread...
I used metric studs in place of bolts and double nutted each stud. I used Permatex "right stuff" and have no leaks in 4 years.
