Hi . i have a Fzj80r 93 with A442F shift problems. I have no OD light off and no drive light when selected.I have a toyota A442F diagnostics document with procedures. I have performed a mechanical test as in i disconnected the solenoid plug from the Transmission and all seems to work ok with manual shifting although the indicator lights still not showing on mechanical test. So i am presuming the electronic system is causing the problem. I have replaced both shift solenoids with genuine toyota parts with no success. Im handy with a multi meter and decided to check the output voltages from the ECT as per instructions.
All but S2 to ground check out as there is 11.8v constant Toyota s range is 0 to 1.5v. This i think suggests that solenoid 2 is constantly on by the way both shift solenoids are new . According to schematic diagram s2 goes directly to solenoid 2 . There doesnt seem to be an explanation apart from a faulty ECT of the over supplied voltage. Before i change the ECT could there be another cause ?
