A442F TC insertion depth
baldilocks
Battle Ground, WA
GOLD Star
Battle Ground
The FSM (not the transmission manual) outlines this step prior to transmission installation but gives no value for the measurement. Does anyone know what this measurement should be? I don't want to be fighting with this tranny install.
Here are my findings:
(from the '94 xmsn repair manual, RM360U)
(from the '95 xmsn repair manual, RM479U)
I know these aren't the same transmissions, but the use the same case castings and I think the same torque converters. I think the '94 manual had an edit error.
It's been awhile since I had the engine and xmsn separated, but IIRC, I think the depth measurement is just to provide flywheel clearance. You should be able to verify the '95 manual's depth measurement from the bellhousing face to the rear flywheel face/bolts. As long as you're proud of that, I think you're good.
I thought I would ask because many have been stumped when they were unable to mate the transmission completely up to engine and I figured that if my 94 FSM left this info out so did everyone else's. Thanks for helping out.
de Nada
