my '94 has 168,000 miles on it. I've had it for about 2 years now and the tranny has a bit of an issue. I'm a newbie to mud as well as the bad-assness of the 80's (which I have come to fully recognize over the last year) so bear with me.
The issue:
When the truck is warm (nice low idle) and I shift into drive or reverse, some of the time the tranny doesn't engage until the rpms come up a bit. It also happens at stoplights. When I go to pull away the motor gets up to about 900-1000 and it catches and the truck lurches a bit. While driving it is flawless, quiet smooth shifts, no power loss. Except when in reverse. If I drive in reverse for 30 or 40 feet, say when you back across a parking lot, it drops out of gear and won't engage again until I come to a stop.
What's been done so far:
It's been pasively flushed (6 months ago), and the fluid has been changed religiously since it rolled of the lot (the truck came with every service record, even the original invoice) checked the level multiple times. It is all good.
The people who owned this before me (family friends) did not abuse this truck by any means, at worst it saw smooth dirt roads and I haven't wheeled it yet (doesn't mean I don't plan to).
What is the typical milage for a A442F befor it needs a rebuild?
Any suggestions?
thanks in advance.
The issue:
Any suggestions?
thanks in advance.
I'm no expert on transmissions, but I've been told not to flush them, so stay away from Jiffy Lube. Rather, your supposed to drain them, change the filter, refill carefully, and go. Being careful all of the time to keep lint out! You might simply need an adjustment, as I'm told the 442F is one of the toughest tranny's that Toyota made. Maybe someone else can help here?
Ned
