A440 rodney flush..fluid type?
I use the Max Life Synthetic and change when I do the oil.
Remove front grill unhook the top hose going into cooler, turn on motor and let it pump it out.
Replace the amount pumped out with fresh.
It's about $20/gallon.
I know of no better way to flush the torque converter.
Total capacity is 14 Qt.
I like to put funnel into tube and when it begins to pump air (whining/gurgling)start pouring in fluid-to flush all out-maybe shift through gears a few times while idling to get valve body. as soon as clean stuff starts coming out shut off. If yours was already clean-guesstimate. Top off.
Put the funnel in the dipstick right?
Just to clarify, Howard705 is talking about a fluid exchange via the trans. cooler which is in front of the rad., search "fluid exchange".
