Hi all,
I recently ran into a problem with my trans. When starting from a stop, the car struggles to actually get moving, it feels as though the transmission is slipping. Does this in low forward and reverse gears. I'm not sure about the higher gears. Sometimes it will start okay low RPMs but usually it needs to get to at least 1500 and up to actually not slip, sometimes all the way up to the mechanical lock up to finally get the car moving. I'm trying to see if anyone might have any idea what the problem might be and what the most practical approach is in fixing it. I wouldn't mind dropping the trans and seeing if its something relatively easy but a transmission rebuild may be a bit out of my skill set.
