A Technical One
Bowen Basin, QLD Australia
Gday,
Can someone please measure for me the diameter of the birfield, where the spindle bush, or bearing runs.
Just trying to sort something out.
Thanks a heap.
Matt
Heres a pic to inspire you.
It may clarify to explain you're looking for the diameter of the axle stub, not the birf. The part where the axle stub runs in the spindle bushing.
DougM
You worked it out ;)
I could edit to change "of" to "on" and add some words.
But your post makes it pretty clear - Thanks.
We're trying to work out if a 105srs spindle bearing which is available seperately will work in an 80srs- for which you have to buy a new spindle.
Only 1 reply, tho - maybe I should have said "what size tyres can I run" or "FREE STUFF" in the title :grinpimp:
Cheers
Matt
From a 97 if this is what you want.
Bill
Great - Thanks Photoman and Landtank.
It IS the same as a 105 in that dimension.
Now if that bearing is 17mmwide and 40mmOD - It should be Bearing - Needle 90364 - 33011
If the Bush - Solid has a thrust face 3mm thick and 55mmOD - It should be 90381 - 35001
Thanks again
Matt
Matt,
Keep us updated on this - interesting development...
DougM
This is a used bushing so could be a little out of round. Hope this is what you are looking for.
Bill
