A/T OIL TEMP LIGHT & no shift
Friday I drove from Chico,CA. to Redding,CA. via I5
fairly flat with some slight grade approximately 60mi.
and 70-80mph. for 45mi.
About the last 15mi. my A/T OIL TEMP LIGHT came on
I kept driving though.
The tyranny seem to be fine until Sunday, I made the same
drive and the same thing happened so we stopped and checked
out the sundial bridge and let the A/T cool.
45 min later checked the A/T temp, the light was off but it didn’t shift
properly.
Taking off in Drive the engine would rev to 2K before movement
and while driving it was really spongy, no downshifting.
I tried starting off in 1st and manually shifting, worked fine.
then went back to Drive, it seemed to shift ok sometimes
It did get stuck in 3rd while in Drive and would not up shift
a few times.
I have 33” tires, stock gears and no extra weight accept
for my lead foot.
Why did it over heat? and should I bother with a
A/T oil flush an filter or is it time to rebuild?
oh yeah...
mileage? Flush the s*** out of it, use rotella or Amsoil... spend the money & get the good stuff... then give it a wirl...if no good, call Dan for some parts I guess...
:confused:
I figured that was a given, A/T fluid was fine and clear
I didn’t pull over the first time because the A/T was working
fine…..(at the time)
I have not driven it today.
190K on odometer 18k on engine and 18K + ??? on A/T
looks to have been out before.
:confused:
:doh: I had the AT oil temp light come on in my FJ62 (A440F). I immediately pulled over and opened the hood with the engine running and let the AT cool down some. I was about 45 min from the end of my trip. The little owners manual gave instructions to let the AT cool using the above method if you get the AT Oil Temp light. About 4 months later my A440F crapped out with very similar symptoms as you describe.
I had it rebuilt. Heat is the nemesis of engines and trannys.
How much further did you drive with the light on?
I drove it yesterday, not good. in D it won’t shift out of 1st but manually shifting it would shift ok 1st & 2nd. 3rd didn’t work at first but then started.
The FSM says the it’s the ?governor & or ?shift valve, (don’t have the FSM with me)
It also says that a retaining plate should be made to hold the ?piston valves in place, it would be nice if there was an exploded view of this.
I’m guessing that the ?piston valves are retained by the valve body which currently has two bolts holding
it in place (it got dark)
Are the ?piston valves going to spring out as soon as the valve body is removed?
As long as you take out the bolts holding the VB to the tranny (refer to the FSM for the proper bolts), the VB just drops out. You have to separate the halves of the VB in order to take out the key ways to take out the springs.
IHMO, Sounds like to burn up the clutches for 3rd and overdrive. These clutches also control reverse. Do you have to feather the skinny pedal in order to get reverse to engage?
Also, IMHO if you continued to drive the truck once the light came on then the TC (Lock-Up) overheated the tranny.
Reverse works ok, a bit of lag, under a second though.
Valve body bolts all 10mm. head.
I take it I must remove the tranny to replace the clutches?
What should I be looking for in the valve body?
the FSM isn’t any help.
I’ve never played with a A/T but my mechanical abilities are at the top of the banana tree.
What does a typical A/T rebuild consist of?
Are there any performance modifications that can be done ? shift kits, stall converters, drilling holes here or there.
Look like I’ll be riding the street bike to work in the rain, fun fun
I removed the valve body today and found that whoever worked on it
last wasn’t very attentive as one of the 4 seals in between the valve body
and the tranny case was nearly cut in half. It was the seal closest to the TC.
This would have caused a major leak under pressure.
Anybody know what this port controls?
Also removing some of the valves I noticed that they were very tight, I had to
push some of them out with a bit of force, while the others came out with a magnet.
Do I need to lap the tight fitting valves?
Use Vasaline when you put the VB/Case seals back in. Worked for me.
I did not lap any valves. After cleaning the VB, I used ATF for the reassemble and they functioned fine.
BTW, do you have the Toyota Ele. Parts Catalog (EPC) on your computer. This may help with ordering parts and a better visual for the tranny as well as the truck itself.
I do not have a copy of the EPC. Thank you for the documents you sent yesterday
Hope your valves aren't scored up(you had to remove some w/force)because they will start sticking when the VB gets hot, causing delayed gear engagement and no shifts.
Dam; there appears to be a list of tranny problems:
https://forum.ih8mud.com/showthread.php?t=138413
https://forum.ih8mud.com/showthread.php?t=138935
https://forum.ih8mud.com/showthread.php?t=138867
https://forum.ih8mud.com/showthread.php?t=138753
https://forum.ih8mud.com/showthread.php?t=138071
What the hell is going on. Someone check on C-Dan; is he sick, in trouble?
Why? OK, now I'm worried about my 442. From what I know so far, if there is slippage, its time to look for a new/rebuilt tranny. This seems to occur at around 135, 000 miles.
Let us put together a list of tranny FU and see what drops out of the data base.
Is this murphy's law at work?
I picked up some diamond bits and files today and
started cleaning up the valve body casting and radius-ing all sharp edges.
Anybody know what and were I should port while I’m in there? to improve the shifting and lockup.
Also how is a 3rd gear lockup done?
Oh ya I stopped by a tranny shop too and spoke with the owner. He said sounds like the governor and typically if the clutches went, there would granular pieces in the pan.
The FSM said it was the governor too.
What's in the pan?
DougM
If your trans has been service by the drain and fill method then yes, there will be a little of that "black sludge" That's normal clutch debris. I didn't know the 442 had a governor? I could've sworn I looked at my Slauson trans parts cd when I bought my 80 and couldn't find a governor. Somebody correct me......:frown:
Probably because I have a ‘A440F’ in my 91
need part # EPC no workey
Could someone with a working EPC and AT manual post the OEM part # for all part with a diamond next to them on pages AT-14,AT-78 & AT-98.
Should be 17 part #
Thanks
