All,
On my way home from work today, I lost all power to the wheels of my 94 FZJ80. The engine runs fine and there aren't any codes showing, but the truck won't move on it's own power. I shifted the transmission through all of the gears in High, Low and with the CDL locked. Nothing made any difference. The engine spins freely without any mechanical noise. I checked the transmission fluid, it's nice and red, no burnt smell and there is plenty of fluid. When the truck is in gear and I apply the gas, there is a small amount of "stuttering", but the truck will not move. The truck only has 125K miles and has been relatively trouble free up to this point. I use it as a DD and haven't wheeled it hard.
Based on my observations, I believe that it is something in the transfer case. What happened was that I was stopped for a red light, and when I pressed the gas to accelerate, there was a definite clunk that could be felt throughout the truck. It felt similar to the transfer shifter popping out of gear into neutral. I initially thought that I was reareded by the car behind me due to the suddeness and intensity. I hit the brakes and when I pressed the gas again, everything was back to normal. I continued down the road driving carefully and moving over to the shoulder. I went a few more miles until I hit the next red light, and it happened again. After the 2nd time, there was no more power to the wheels.
There are no mechanical noises and no obvious external signs of failure. Does anyone have any ideas on what this may be? Based on the milage and the care that I have given the truck, the components should have a ton of life in them. I have only had the truck on the road for a week after a headgasket repair, and I am getting a little frustrated at this point. I won't really be able to work on it until this weekend, but I would appreciate any help pointing me to the likely culprits.
Sorry for the long post, but I wanted to give as much info as possible. Thanks for any help in advance!
Clint
Clint
and
