A request
Tacoma, WA
I ended up removing a viper anti theft system from my 91 cruiser. I have a crank but no start condition. I'm sure the wiring I pulled needs to be reconfigured. I was wondering if someone could snap a few detailed pictures of the wiring under the kick panel (below the dash). I could use it as a reference to reconfigure my wiring mess. This is my only vehicle I have at the oment to get me to work. Thanks in advance.
What viper anti-theft did you remove? Unless it had an ignition kill feature it shouldn't be an issue.
It says Model: 300
Whe it was installed my cruiser wasn't starting either. I keep hearing an annoying beeping sound when the key goes into the ignition. It stil does it with the viper system removed.
The DEI manual Has starter kill ready circuitry. Meaning there is the option of a starter kill module. Look underneath you steering column armor for wires tapped into the ignition harness. If there are wires tapped in, your ignition harness has been severed and needs to be spliced back together.
