A little Help Please....Electrical...AGAIN
Kansas!
jakes cruiser is running better than ever!..took it out to the 80 today and put it through it's paces...shifts ok for a 3 speed...transfer case engaged great ...motor running good...brakes ..well ok for drums..steering still a little tough..climbed some tough stuff...get home and the damn left turn signal is not working...blinks dim on the dash...rear turn signal dim....no turn signal at all on the front...checked the bulb..it is good...started tracing wires....power at the connections near the switch under the dash...power thru the fire wall...no power at first wire block...no power at second wire block...cut and spiced a piece of wire on at fire wall...put a connector on the end...test light flashes great...hooked to first wire block and it seems to die....once hooked to the first wire block...no power...real strange...could the ground be bad at the first wire block?...or am i missing something else...i have been through this before..sometimes i get tired of the electrical issues on this truck!....the wire seems to get warm when i hooked it to the first wire block?...any help is appreciated!
thanks
osagecruiser
Marc, clean connections and make sure you have a good ground.
Ed
Short circut
Sounds like you have a short circut there. Possibly, the insulation is broken somewhere past that first block which is causing most of the power to short circut straight to ground. When you cut the wire and spliced it with a new wire did the rear light get bright again or was it still dim?
It could be a number of things: A bad connection anywhere between the fuse block and the ground. Since both the front and rear have problems, a single ground problem cannot account for it because they have separate grounds. It could be a short too, but these are much more likely to cause a fuse to blow instead.
ok fixed that...i guess i should always start simple things first...turns out the turn signal was loose on the fender...tightened it up and it works....only wasted a couple hours tracing wires...oh well lesson learned
osagecruiser
