After adding drawers last winter, the 80 sat pretty much arse-heavy like this on stock suspension, with the original shocks:
2007048.jpg[/IMG]
Thanks to the help of Hants and Tim (MomentRider), the Silver Hippo, formerly the Silver Bullet, now sits up a bit more: (OME Medium lift, no spacers)
Sadly, Hants trusted me to pick out the left and right springs to put on the rear. A day later, I kept thinking that the Hippo was leaning to the driver's side. After re-reading Slee's instructions and looking at the A and B labels, I discovered that I had screwed up the rear springs. Newly confident in my minimal wrenching skills, I recruited a friend to push down on the axle for me and swapped them out in an hour with no problems, save for the bushing coming out of the bottom of the OME shock. This was fixed without removing the shock by using a Quik-Grip clamp and some scrap wood.
The LSPV adjustment was pretty easy- I hit the bolts and the whole LSPV bracket with Liquid Wrench for a couple days, and it came loose with no problems. I moved the frame side down .25 inches, and was planning on fine tuning using the axle side of the LSPV, but based on rudimentary lockup testing, there is no need for any more adjustment.
I've also added a few (5) power outlets. They're run from a 6 position fuse block (NAPA) attached to the passenger side kick panel. Power runs direct from the battery via 8 gauge wire to a 50 amp auto-resetting breaker mounted on the outside of the battery enclosure, with 8 gauge the rest of the way along the firewall to the PS grommet. I used 10 gauge from the fuse block to each outlet.
A "hidden" outlet that's held on only by Amazing Goop (zip ties have since been cut off):
Trying to look OEM:
And using the drawer wings:
Tomorrow the CC bushings and alignment should be done using Landtank's template, and then I'm off to Arizona for fall semester. I have also done the CDL switch and 7th Pin mod, but pictures of that are pretty uninspiring.
2007048.jpg[/IMG]
Trying to look OEM:
