a few hg ?'s
Atlanta, Ga
Ok it's late and I'm really tired so if one of these is a dumb question please forgive me and please don't say search because I'm not in the mood right now. First off, what size are the head bolts? Secondly, I took off the exhaust cam shaft without putting in the service bolt and of course the teeth don't line up anymore. How can I fix this while its on the bench some how? And finally, what's the best way to clean the inside of the intake manifold? Sorry for all the questions.
Thanks everyone.
ps. that hg dvd and the little sheet that comes with it are amazing. Thanks
just got up and am in a much better mood ready to start working. thanks for the help
Yep, I did the same thing, did not place the service bolt before removal... not a good idea.. but should be ok. Even if the gears line up , as they did with mine, you MUST still rotate the gear (to get the spring tension back) and get the service bolt in prior to re-install.
If you have not done this rotation before, it can be a little tricky. The FSM kinda shows this... In order to rotate the gear you place 2 service bolts into the non-threaded holes on the gear and use a long screw driver between them (one end of the screw driver is on top of a bolt and the other is below a bolt) and then you simply move the screw driver in a clockwise fashion until the threaded hole lines up.
Here's my thread on my HG repair... you may find some useful tips in there as well. ... https://forum.ih8mud.com/showthread.php?t=156816
Good luck !
--don
