A/C Wiring Diagram Help
Plano, TX
So I'm in the library this morning flipping through the EWD looking at the A/C circuit and had a question, why does my wife always insist on talking to me when I'm in dispossed of? :D
No, really...past posts lead me to believe that there was a signal sent to the compressor that turns it off when the truck is over heating. I was thinking temp sensor to ECU to A/C compressor. Or is it the A/C amplifier to the A/C Cut relay to the compressor, correct??? Am I also correct in that the amplified is sensing the evap temp is too high (or pressure too low / high) and has nothing actually to do with the coolant temp?
Or does the signal come straight from the ECU?
Or both?
From the 1991 schemo....
2. AIR CONDITIONER OPERATION
WHEN THE BLOWER SW IS SET TO ON, CURRENT FROM THE FL HEATER FLOWS THROUGH THE A/C FUSE " TERMINAL 1 OF THE
A/C PRESSURE SW " TERMINAL 4 " TERMINAL 3 OF THE A/C AMPLIFIER. THE EVAPRETOR TEMP. SIGNAL FROM THE A/C
THERMISTOR. IS SUPPLIED TO THE A/C AMPLIFIER. WHEN THE A/C SW IS TURNED ON, THE A/C SW ON SIGNAL IS SENT TO
ACTIVATE THE A/C AMPLIFIER. CURRENT FLOWS FROM THE A/C AMPLIFIER TO THE MAGNET CLUTCH, TURNING THE
COMPRESSOR ON. AT THE SAME TIME, THE CURRENT APPLIED TO THE ENGINE ECU FLOWS THROUGH TERMINAL 7 OF THE
AMPLIFIER ACTIVATING THE ECU TO PREVENT ENGINE SPEED DROP IN A/C OPERATION. THE A/C OPERATION IS SHUT OFF WHEN
A SIGNAL INDICATING LOW EVAPORETOR TEMP., OR ABNORMALLY HIGH OR LOW REFRIGERANT PRESSURE.
WHEN ONE OF THESE SIGNALS IS RECEIVED, THE AMPLIFIER SHUTS OFF THE A/C OPERATION.
IOW, it doesn't give a hoot about engine temp. I know this from experience when my fan clutch was faulty. Engine temp would climb and the AC would continue to blow cold. I always watch the temp gauge when running the AC.
