It is getting hot here in florida and i noticed my ac is not very cold at idle- I recently charged the system- And it is super cold when the truck is in motion. Compressor maybe? thanks-
fan clutch
With the fan it drops 10 to 15 degrees. Brother Kevin (ToolsRUs) did the fan clutch mod with simular results. Good luck.thanks for the help- i will get one from Dan next week- How does the fan clutch help the ac? Just by cooling the motor more? thanks!
I added a Toyota 12" electric fan I got at Pull-A-Part for 20 bucks. Mounted it right below my electric horns and hooked it up to a relay taking power off my AC compressor. It's cold anytime including the long waits in drive-thru's and probably helps my fuel economy since my fan clutch isn't engaged all the time.
e9999;[URL="c2c://3381060" said:3381060][/URL]above all sounds reasonable but wondering about the numbers.
with the original design working well per specs (not degraded as in bad oil), at what outside temp would the clutch be engaged "fully" at idle with a/c on? Would it even turn on fully if the engine is just idling at normal operating temps (say 180F)?
