A/C Update and Game Plan
Dallas, TX
ok.. it is summer and it is hot as hell in Texas...
Here is my plan.
I just got my AC tested and charged. at the AC shop... the AC shop says all looks good but still I am not happy with the coolness....
Baseline: I will 1st measure my vent temps and ambient temps for reference.
Stage 1) Upgrade blower to 2004 GMC Yukon blower (just ordered)
Stage 2) Wrap AC cold line with cold wrap
Stage 3) Clean Condensor
Stage 4) Evacuate system, remove and clean evaporator, replace expansion valve and replace dryer. Refill/ charge system
Stage 4) Upgrade to high end condensor pusher fan (I have an older Delco 14" on there now)
Other cooling mods already in place:
  • Hood Vent
  • Pusher fan on condensor
  • New 94 radiator
  • Temp gauge mod
  • Fan Clutch mod
I will measure vent temps at each stage providing the ambient temps and the temps at the vents with A/C on max and recirculate.....
Any thoughts?
I wonder why yours is not cooling? My 91 with original parts will freeze you out! I would look for leaks and vac. and recharge again first. 2 cents Mike
When you guys recharged, did you do it yourself with one of those kits? Or get it done? I'm looking to get my truck's A/C going good again.
A kit is ok if you watch your pressure,But,if you suspect a leak get someone to pull a vacuum and check for leaks,the system must be closed so as not to let moisture in which could freeze and block the flow.My guess condensor or compressor is leaking. 2 cents Mike
My 97 works very well down here. There is the possiblity that the system may check OK but still be freezing up at the expansion valve preventing proper heat exchange. This is due to the filter dryer becomming saturated with excess moister in the system. The only soltuion is to evac the system, replace the expansion valve, filter dryer and then recharge. We had to do this on my dad's '95 a few years back. I'm not sure why this ever happens but a shop should have caught it right off the bat.
the shop I took mine to only does AC work. They said all looks good... but it is nowhere near the cooling of a Dodge Charger we rented last week. On the charger we measured the ambient temp at 92 degrees and at the vents with the AC on high, we measured 59 degrees... I would like numbers in this range for the cruiser.
I must be way off then cause the cruiser doesnt come close.
To whom?
No way is 60* vent-temp air going to cool a Cruiser on a 90* sunny day.
Oh I agree that won't do crap to cool a LC but most a/c service manuals will state that. It is the min. acceptable amount but I'd hope that is also at like 100% humidity at 100*. I could also be mis-quoting that, it could be 40* difference but 30* stands out in my mind. --Which might also account for why the shop is telling citadel that everything checks ok.
My 62 with R-12 100outside,I measred 38 degrees at middle vents. Mike
R12 is way more efficient thatn r134a, so I'm not surprised by that. Even my '86 pickup with converted 134 is running 38* air at the vents.
Citadel,
Which A/C shop did you use for the work? I have an 87 FJ60 here in Austin that needs R-12 recharged but cant' find a shop to do it. Everyone wants $300+ to convert me to r134. Driving me crazy! Suggestions?
I used AC Authority in Round Rock
Initial Results
BASELINE:
RESULTS: Ambient Temp: 100 degrees
Temp at Vent while idle: 67 degrees (AC on Max)
Temp at Vent while driving: 60 degrees (AC on Max)
Stage 1) Throughly Cleaned Condensor with Simple Green
Temp at Vent while idle: 60 degrees (AC on Max)
Temp at Vent while driving: 52 degrees (AC on Max)
Stage 2) Upgrade blower to 2004 GMC Yukon blower (just ordered)
Stage 3) Wrap AC cold line with cold wrap
OOoooo.....
Go Hanahan Hawks!
I don't know what to say. I'll drive down to Austin to save you some money if you'll pay for my gas and troubles. WOW. 52? The compressor never get a breaks at that temp.
More air across the evaporator is going to raise the vent temperatures. Who is giving you advice to do this?
