A/C system
Utah County
Hello, I have a 1996 Lexus LX450 with 202k miles on it. The A/C blows pretty cold, but when on the compressor sounds like a bearing is going out (quiet when A/C off). I assumed that the compressor is going out. I have a trip planned in 10 days and need to get this up and running. Do I need to just buy a new compressor and drier or is there more that needs to be replaced while I am there? Thanks in advance for the help.
Jason
Post up a YouTube video of the sound, might help to diagnose.
If it sound funny from the compressor, then it is a ticking time bomb. If you were to replace the compressor and drier, is a good idea to replace all the o rings within the system, remove and clean the evaporator, and replace the expansion valve as well. Vacuum the system, fill with appropriate amount of refrigerant and oil and you will have a healthy ac system.
Here it is. I used the dowel test while out there and there is more noise coming from the tensioner pulley. I thought I did that test before and it was clearly the compressor. Would the increased pressure of the compressor make the tensioner pulley squeal like that?
Yes, it would. I would think it is the tensioner (idler) before the pump.
I am not finding the tensioner on Autozone or Orielly websites. I would like to do this over the weekend and dont want to wait for shipping. Does it have some strange official name?
Not sure I would start replacing all o-rings, evap, and TXV, if the problem was with the compressor. I did replace my evap and TXV last year, and some o-rings, but that was because I had the dash out, and figured I would have a look at the evap since it was easy to remove, and the A/C system wasn't working. Turns out the evap fins were corroded a bit, but it could have probably been reused. However, I replaced it along with TXV as a bit of preventative maintenance.
Ok, I sprayed some lithium grease into the bearing area and noise gone. Now ill try to track down a new pulley.
Remove the pulley, take the snap-ring out that is holding the bearing in, tap or press the bearing out, take it to the parts house to match a replacement. Don't recall the bearing number but it's common, ~$6.
Ok a new tensioner pulley was found. Now while looking at this pulley, it seems like it can move front to back quite a bit. Also there isnt any grease at all on this. Should I grease the hell out of it before installing? Also is all the movement normal?
Anyone know if I should grease it or just install it dry like it is straight from the box? I am hoping to hear so I can finish up this replacement. Thanks :beer::beer::beer:
Nevermind, I just installed it the way it is right out of the box. All tightened up and quiet. What I noticed was, that the pulley wasnt even adjusted at all. It was the loosest it could go and the belt was very loose as well. I also changed out the belt and it was way smaller and had to be cut off to get off the crank & A/C pulleys.
Thanks for the info and assist on this. Saved a lot of money only fixing the pulley and not the compressor and dryer. :cheers:
Glad you sort it out
