A/C slowly dying
Utah
OLD THREAD UPDATE 7/15/09 - YAY!
OLD THREAD 9/20/08
Lately I've noticed that my A/C is slowly getting worse and worse. Original R12.
At the beginning of Summer (late spring, April/May), I noticed that it had a hard time keeping up with the rising heat. But, only after driving for at least 20 minutes, it would get down to a good bone-chilling temperature. It worked PERFECT at night.
The months went on, and the AC had to work harder and harder. I replaced the fan clutch (Napa. Yeah, be quiet.). A/C got better, but for only a few weeks. Slowly but surely, it got to the point where it barely cools the air - if at all - even at night.
Thankfully, I can deal with some wind in my face. So I've been driving with all the windows down.
Time to replace some seals? Recharge? Or is there possibly a leak?
I'm not to hot on A/C systems... The extent of my knowledge is that R12 and R134A aren't compatible, and I don't want to convert.
Somebody edumacate me, please.
Sounds like gas is slowly seeping out. This will be pretty easy to find with some dye and a black light. I would not underestimate the junk value of the NAPA fan clutch. I put one in my '94 when mine started having similar ac issues last summer. It did not last very long. I have used NAPA parts professionally for over 2 decades. But two of their fan clutches (reboxed Hayden units) let me down in no time at all. I chose to go back to an OEM and filled it with 20,000cst.
Look for a leak first, and post your findings.
BTW, Does your compressor still kick on?
Easiest thing to do is check for bubbles in the sight glass. Once the compressor kicks on and the engine idles up, it should bubble for a second or 2 and then run clear. If it doesn't run clear, then you're low on gas. If it runs clear then you should go to an AC shop with the FSM open to the correct page and have them do a pressure reading.
In any case, you know that using a non-OEM fan clutch will lead to problems. Replace that ASAP.
Without a set of gauges you are limited to just a few ways to diagnose. You can verify if the fan clutch is not pulling enough air to cool the freon by running water over the condensor. How is the vent temperature then?
As mentioned, check the sight glass. Leaks, sometimes, will be fairly obvious, look for black oily residue on the a/c fittings, compressor manifold plate, lines, etc... Check your schrader valves, if there is enough pressure in the system you can use some soapy water in a spray bottle to see if they leak. Schrader valves are the most common source of leaks in an a/c system. They may not appear to leak, for instance, the low side is not leaking when you first check it (car off), then you turn it on (a/c too) and no leak, but when the pressure in the system equalizes (high and low are the same) after you turn it off again, it will leak, and will continue to do so until it gets to a certain pressure. It sucks if that's the case and you have some amount of freon in the system b/c you will lose some, most, or all of it depending on how fast you are at changing the valve. There is a special valve tool to minimize the amount lost.
If I were guessing, you have either a leaking schrader valve, or the compressor is not pumping as it should.
The compressor still kicks in. It idles up, then my acceleration sucks.
I never thought to check the sight glass....that's on top of the silver cylinder thing, right?
Well, sight glass showed a lot of bubbles, and no clear.
Fan clutch is still holding up just fine, amazingly.
Also, the compressor just stayed on. It didn't kick on and off every 10 seconds like it would normally.
Unfortunately, my PS pump (which sits right above the compressor) has a small but steady leak. There's PS fluid all over the top of the compressor.
When I first got my '91 80, it had the same issue going on. It was making a godawful noise due to it being low on ps fluid. I filled the reservoir with fluid and cleaned it up with engine cleaner. I found it was slowly leaking ps fluid from the area of the rear plate. I cleaned it again, applied a bead of high-temp silicone and voila! - no more leak.
My backup plan if that didn't work was to bolt a cover with high-temp silicone as a gasket to the rear of the pump. There are two factory threaded holes on each side of the housing. This would provide a secondary seal. But the fix worked. It's going on +3k miles since then and it's still fine.
I would find the source of the leakage first. Look in the typical places at the seals at the compressor shaft, leaky schrader valves, and around the accumulator and sight glass. I would then evacuate and recharge the system using a direct R12 replacement gas like 401a or 401b or R12 if you wanted to spend some $ on R12.
134a conversions can be done cheaply, but when they are they will; wear out compressors quickly, eventually causing leaks at the same time, and, your factory R12 condensers are not sized for efficient opeartion using 134a. If the 134a conversion is done correctly, it is expensive (new compressor, filter dryers, xpansion valve, seals) and it still works your compressor and system hard becuse the factory condenser is not sized correctly.
I have been safely using a direct R12 replacement in mine for years. Fully compatible but you need to be or know an HVAC/refrigeration tech to get the gas to charge your system.
compressor shaft....accumulator
Huh? :confused:
401a or 401b
Where would one like me find this stuff?
That's why I have no interest in converting.
Thanks for the info. :)
When I was in your situation (compressor still kicking in, but low refrigerant as shown by bubbles in the sight glass), I got myself certified to legally buy/use r12 (the real stuff) and then topped it off. :meh:
This was several years ago, and it's doing fine.
Curtis
Curtis
How do you get certified?
So I finally did something about my A/C. I took Curtis' advice and got myself certified to purchase and use R12.
Saturday the 11th: Armed with a recharge kit and one 12oz can of actual R12, it took an hour to figure out that, once I had everything hooked up, I still had to puncture the can with the tool in order for refrigerant to flow... :doh:
Within a few minutes, though, Katie's AC vents were blowing out a cool 43 degrees. And just a few days ago, I measured a bone-chilling 38 degrees.
Certification: $20
Can of R12 + recharge kit: $48
Total: $68
"Proper" R134a retrofit: $^%*&
I
cold A/C.
