My rig is a '94 and has a vortec 5.3l swapped in. I am using the compressor that came on the vortec (2006 MY). It's a R134A system.
I had custom hoses made up and installed a new receiver/drier and replaced all of the orings that I could get too.
I vacuumed the system down first to check for leaks (non found), and then to dehumidify for 45mins.
I charged the system using a digital kitchen scale to measure out the freon going in. The engine was at a fast idle of 1200 rpm while charging. I think I goofed it though.
I am seeing vent temps ranging from 45 to 55 degrees and my pressures on the manifold show about 25psi on the suction and 275 on the discharge side. These pressure willl drop if I lower the vent fan speed.
Did I overcharge the system? I feel like I need to have it discharged, suck it down again, and the recharge again. Maybe my compressor is not up to par?
