A/C recharge issue
Gainesville, FL
I just replaced my compressor and o-rings/drier/condenser. Before putting a vacuum to it and refilling with refrigerant I wanted to test the compressor. When I turned on the A/C, the clutch on the compressor did not engage. It's not the new compressor. There was no power going to the compressor. Would that be the case normally when the system is empty or not under a vacuum?
This is correct. It has a high pressure switch and a low pressure switch. If all the Freon and oil leaked out, you don't want the compressor to run because it would burn itself up without the precious lube.. You can jump the pressure switches with a wire across them for a very short time, but it is usually a trouble shooting move. If you want to test the clutch, you should be able to use some wires straight from the battery.
Thanks. So when I get a vacuum and start to add freon the clutch should engage?
Yes. Think of a switch- once the pressure gets above the rated value (adding refrigerant) of the low pressure safety switch, it will then complete the circuit and let power through to the clutch, which engages the compressor.
I usually start the first can without even starting the engine (don't just dump the can with the valve wide open, keep the pressure under 40psi), let the pressure equalize between the can and the system, then start the truck and suck the rest of the can dry. The compressor fires right up with most of a can in there.
