A/C questions
So. Austin, tx
My AC had stopped cooling... yesterday I pressurized it nitrogen, leaked checked, pulled a vacuum & then filled with oil and 2.5 cans of Freeze12, but if does not cool... compressor does come on, etc.
I was in a hurry when I was doing it so I did not spend a lot of time diagnosing. I was noticing that after I would put in a can of refrigerant, the pressure on the gauge would go up and then would start to drop to a vacuum. Why? The low side is the bigger diameter hose, and the port is a few inches away from the compressor, correct?
Truck= 92, 22RE
Did I miss something?
Thanks in advance,
ML
No mods, I've had this truck since new...
Freeze12 was the only this I could find at a reasonable cost and no I did not flush. I thought that freeze12 and r12 were compatible? I did run a little nitrogen first and then vacuumed.
You are probably better at this than me,but I hear good and bad about freeze 12. My a.c. supplier in Irving always recommends a full flush when changing between 12,-freeze and 134a.Also changing out the dryer too. Just a thought. MIke
I am no better... Do you know how to or what to flush it with? I do have a new filter/drier whick I have not installed. I was thinking of doing the r134 conversion but figured I'd try the freeze12 idea first...
