A/C Question.
splitshot
Head cook, Bottle washer, and Peace keeper.
Rodent Central, Az
If got a system with a slow leak, it'll take a charge/ work fine, but after about 24 hours the compressor will start "short cycling".
Without going through the bother of tossing some dye in, do any of the stop leaks on the market work?
I have a similar thread going on now. I used the do-it-yourself Freon kits with the U/V dye and stop leak added, but also I bought the mini tool used to tighten the A/C schrader valves and checked all three of my valves (thanks to all that pointed me in the right direction).
Cool, (no pun:D). I've been hands on with some techs with three different rigs now, and am learning alot. A neighbor has lent me his guages and athough I am not an expert on this, I think I have a reasonable idea on how everthing works.
I'll check out your thread.:cheers:
I'm actually in the middle of an A/C question myself... I just replaced the HG on my FZJ 80 and have a problem now where the magnetic clutch won't engage when the button is pressed. The light on the dash turns on and a relay behind the glove box clicks... but no power to the AC clutch... Am I missing a connection somewhere?
On one of our company trucks we replaced the dryer and orface assembly, evac'd the system, recharged, only to have the same symtoms: random "blow cold and then go warm.":hhmm:
No set pattern to this, finally I swapped out the a/c clutch relay with the horn relay (they are the same), and it has wored fine since..
Usaully when the clutch doesn't work, there isn't enough refrigerant in the system to make the low pressure switch activate it. I would go there first.
Stop leak assures you that you are going to lose all your freon and the stop leak (if it's a competent shop) when the problem is fixed. See the other thread for common leaks.
Not sure on the electrical connection problem, if all the wires are hooked up, I'd have to be inclined to say it's low on freon as a result from the HG job and swinging the compressor out of the way?
Look for black oily.
