A/C didn't work in the truck when I bought it about 3 years ago but just adding freon would get it going again. Every few months I'd add a little bit more until winter. Finally decided it was time to fix it before it gets hot here so I replace the evaporator core, expansion valve, and dryer this weekend. I pulled a vacuum down to 30 and it held so no leaks. I added about a can of freon and the compressor cut on but never started to cycle. Low side pressure is showing ~35 but low side is only around 60. No cold air from the vents either. The system was cooling right before I pulled it apart (aside from the leak) so I'm a little confused as to where the issue might be now. I've been searching for about an hour on here and the web and most points to the compressor.
Any ideas?
Any ideas?
