Trying to condense a long story-
'93, when purchased in 2004 A/C worked ok, charged with R12, worked well for a year, tried to charge it the next year, system would not build pressure on the high side. (bad compressor)
Few years later, buy cheap new compressor, new Toyota expansion valve and reciever/dryer and some "Freeze 12," and try again with help of buddy who now looking back probably didn't know very much (still more than I did at the time.) Compressor worked for a short time, then seized.
Fast forward to the present- New Nippondenso (OEM) compressor, new reciever/dryer. Have vac pump, manifold gauge set and freeze 12. Go to work and immediately see what I now know are R134 conversion fittings on the compressor. No conversion stickers anywhere.
So now I don't know if my system ever had R134 and specifically PAG oil in it.
The original plan was to change receiver/dry and compressor, add appropriate amounts of Ester oil to reciever/dryer and compressor (after draining whatever it came with), vac system, check for leaks, charge with Freeze 12 and go.
Reason I mention the PAG is that it is not at all compatible with mineral oil. Everything else that could be in the system is compatible with what I am putting in (Ester oil and Freeze 12).
I am wondering if I should now go through trouble of flushing, since it seems to be a tossup as to what all is in the system now. I also read mixed reviews of flushing in any situation. No sign of metal particles or trash in system after removing old compressor, old lube looked very clean.
Also- I need an adapter fitting for my 3/16 high pressure schraeder fitting to my old R12 gauge's 1/4" fitting. Anyone know where to find one? Also thinking I may just stick 134 adaptor fittings on there since R134 gauges and fittings so much more prevalent.
