A/C Issues - Need Help
Oman
Hi everyone,
My main AC blower has stopped blowing air to the face. It works okay in all modes except face option. Has anybody got an idea on what's wrong or how to fix it?
Appreciate any support
K
Hi everyone,
K
Can you explain what you mean by "face option"?
Do you mean that the top blower on the dash does not blow?
The driver, passenger and center blowers do have a shut-off device at each blower, but I'm not sure what you mean.
Yes, the air flow to the upper body has stopping working. When I use the mode button to select demister, foot they work okay, but when I re-select the face or upper body option, it only directs the air to the foot option. This is a manual display i.e. without the Multi-display.
The AC still blows cold air, so i guess nothing wrong with the gas,
Ah.
You have a very different control system (not screen/display based like USA Land Cruisers), but you probably have the same electronically controlled vent and airflow motors that redirect air to different locations behind the dash. Perhaps a fuse that feeds those motors is blown? There are at least 5 A/C fuses that feed various functions. At least two of those feed the compressor, but one of the other 3 would be easy to at least check.
Others here with FAR MORE knowledge will hopefully comment...
Ah.
Thanks Markuson. I will check that and revert my findings.
Markason,
I dpn't know what too place, but today it started to work properly.
Strange?
Nevertheless, thanks for all your support.
