For the past couple weeks I've had diminished A/C performance, as well as some noise from the compressor. The belt has been squeeling as well. So I replaced the belt with a cheapie from Autozone over the weekend, and this resolved the slipping/squeeling of the belt. I then had a A/C diagnostic done by a local shop I trust this morning. They checked low side and high side pressures, and added 0.3 pounds of r134a. This helped quiet down the compressor a bit, and improved the vent temps, but they are still not normal. They diagnosed it as a failing A/C compressor.
So I'm planning on acquiring all the needed parts, and then going back to have them evacuate the system. I will then perform the component swaps, and then bring it back for them to pull vacuum and charge the system.
My goal is to get the system back to new performance, and have it trouble-free for the next several years. I'd like some help compiling a list of what should be replaced. I'll start a list of the obvious that I've accumulated through searching this site and others. I'd like some advice from the experts on what else I might need, or should ask the shop to do without throwing my money away. The shop recommended just the compressor, expansion valve, and drier. I'm wondering if I should also replace all the o-rings that I can get to, or anything else.
Here's what I've got so far:
Denso 10PA17C A/C Compressor (new) with clutch for FZJ80 ~$200 online
Expansion Valve 88515-20100 ~$60
Receiver Tank (stock) 88471-50020 ~$35
or Receiver Tank (3/4" shorter than stock) 88471-34010 ~$30
V-Belt for A/C 99332-10910-83 ~$8
V-Belt Pair for Fan 90916-02353-83 ~$10
A/C Idler Pulley Assy 88440-26090 ~(no pricing) or just replace the bearing with 6301-2RS ~$5
Then I've got a list of some other oem items in the A/C system that I'm not sure if I need. These were quoted by my area parts guy when I requested he include part numbers of all the o-rings and any in-line filter in the system. Some of these I may need to talk to CDan about exactly what & where they are:
O-ring (qty 10) 90069-08007 ~$5
O-ring (qty 10) 90099-14119 ~$10
O-ring (qty 10) 90068-14010 ~$25
Gasket kit, Over 88335-14020 ~$1
Tube & Accessory 88710-60480 ~$15
I've also got numbers and pricing on some other items I may replace "while I'm in there" since most items are still original on my 140K mile rig. Just trying to keep my footing on this very slippery slope.
Fan clutch (blue hub) 16210-66020 ~$125
Alternator Idler Puly Assy 16603-66010 ~(no pricing)
There's more of course
, but it's in no way related to A/C performance.
I could probably go cheaper with some aftermarket parts, but I feel more confident in all OEM parts in this system. What do you experts think about the parts needed? Anything else I need or should know going into this?
Thanks in advance.
, but it's in no way related to A/C performance.I could probably go cheaper with some aftermarket parts, but I feel more confident in all OEM parts in this system. What do you experts think about the parts needed? Anything else I need or should know going into this?
Thanks in advance.
Good luck.
