A/C dryer
Carlstadt New Jersey
Has anyone ever had the ac dryer corrode where the carbon steel bracket touches the aluminum housing? I found a small puddle of clear oil under the front of the truck. I removed the blinker and the top of the dryer does not seem wet. I read the O-rings will eventually dry out and leak.
Does anyone know the part numbers for the O-rings for this part? The stealership I get my parts from doesn't know and the diagrams they have are garbage and don't show the part numbers for the O-rings.
Most parts guys are not going to waste their time looking up a couple of O-Rings for you.
Just buy an O-ring kit....match the size up from that.
'A/C System O-Ring and Gasket Kit Santech Industries MT2580'
Few folks in the detailed AC core replacement thread mentioned that these are metric specific and do not come with generic o ring kits, and had to source Toyota ones. I’m probably going to get an assortment from Toyota and try to match them up.
I noticed Rock Auto and most supply houses carry the o-ring kits for the entire ac system.
Suit yourself...but the kit I posted should work just fine for you. 'A/C System O-Ring and Gasket Kit Santech Industries MT2580'
Here is a little tip for you (and others doing A/C work). Don't install any O-ring or make any connection without using 'Nylog'.
Nylog is your friend. Make the extra effort to get a bottle and USE IT. You will have no more leaks (from connections or O-rings).
RT201B Refrigeration Technologies NYLOG BLUE (HFC/POE) Gasket - Thread Sealant
