A/C condensor pipe
Colorado
As you can see, the pipe I have is in a meh/bent shape, and since the rig is in the shop, I'd like to see if I can source a properly shaped replacement.
The core support was recently repainted, and I'm thinking what better time to address it while things are removed.
What would be your recommendation on where to find a properly fitted pipe? I also got my hands on an OEM New used part A/C condenser, so I would like to see if I can address it now.
Thoughts or ideas?
was it a hard line all the way?
original would have been hardline across the condenser then switch to a soft line
It was a hard line before/now. I had an aftermarket condenser that needed the pipes reshaped, as shown in the first picture. Now I'm trying to figure out what to install in its place because it isn't in a good enough shape to repurpose.
I am curious as well what you come up with. I ordered the exact same condenser. Literally was the only option in US for a new replacement.
