when idling in the heat with A/C on the truck begins to shutter after about 5-10 minutes, but not always. The idle goes up and down (from 600-900 aprox) as if the engine is starved of fuel or low on radiator fluid. I opened the hood up and the A/C compressor was making a low pop or click noise as it shuttered. This caused the temps to creep up, the A/C still blows icy, and a step on the throttle will remedy it for a little while. If the A/C is shut off, it stops.
FC is modified, A/C is R/134 upgrade, everything else stock. This truck has always started bad since I've owned it also. After it turns over it is somewhat quiet, stutters a little, then starts idling.
. After I get the high pressure line checked I'll let you know what I find out. I have never messed with the refrigerant since purchase in March 2015.
