I just replaced the HG on my FZJ 80 and now have a problem where the magnetic clutch won't engage when the inside A/C button is pressed. The light on the dash turns on and a relay behind the glove box clicks... but no power to the AC clutch... Did I miss a connection somewhere? (the compressor is not seized and the inside pulley turns freely). Does anyone know if it is a straight 12V signal to the magnetic clutch or is it ramped down to a lower voltage. The connection to the A/C compressor is fine and the connector behind the washer fluid tub checks out, but I don't know how to track the problem down from here. Any help or ideas would be greatly appreciated!
