A/C blows
How many people on here got an 80 series, that runs close to perfect (except for speed wise lol) and the a/c is terrible, thats only thing i got to complain about my 80. Well other than the necessary 350 haha
It seems that most people with bad ACs either need a recharge, or have overheating problems. There are a lot of threads discussing the different fixes if you do a search.
They all suck..my 95' is horrible and I've done/replaced practically everything.
I am doing my Blue clutch fan mod as I write this....this had better work.
airlaird
airlaird
Mine blows 47 degrees on a 98 degree day.
IdahoDoug has mentioned that if you spray down your radiator and condenser fins with a good degreaser, let it sit and then hose down this gets the road grime out of the fins and allows for more efficient heat exchange.
I didn't have any AC issues but did this and a lot of trash came out.
There is also a thread regarding cleaning the blower fan which can build up a lot of trash over the years.
airlaird
Steve,
Are these your thoughts after putting in the GM blower? I thought you were pleased with the performance after this mod.
Buck Buchanan
My A/C sucks only when sitting still (which is all the freakin time driving around town).
Probably gonna clean out the radiator and condenser tonight and see if that helps.
If not an aux fan is going to be my next mod.
Thanks for all the advice. I think there is a leak somewhere, and believe me i have tried everything to find it and after no luck i had one of my buddies switch it over from the 134A? to the cheaper stuff because i was tired of wastin all that money to keep refilling it.
I had contemplated switching over to 134 when my R12 system leaked, and I'm glad I didn't...it was a seal at the compressor that was bad...replaced, and recharged with R12 and it blows in the 30s on a 100+ degree day...blows in the 40s when sitting still on a 100+ degree day. It's hard to beat the cooling efficiency of R12. Compared to my wife's car (2000 Beetle, which is horrible on really hot days), I'd stick with R12 any day of the week. ;) There's just no reason to switch as long as your R12 system is working as it should, and the truck is in good repair.
My '97 A/C will freeze you out....everything is factory original in the cooling department....well, except the 'blue clutch fan'..
I can leave my rig outside with the windows up in 100+ degree weather all day and get in it and in about two minutes it's blowing 'ice cold'...
sorry you are having trubs....:beer:
Steve,
Buck Buchanan
The blower works well...but the A/C is back to nominal. I just did the Blue fan clutch...no difference at all....I'm at wits end..
airlaird
airlaird
How are your pressures?
If everything is in spec, you might look into a new condenser. Your AC guy should be able to tell you for sure. Does it only suck at idle, or is it marginal going down the road too?
Hmm, I seem to remember that you have an AUX fan already. If that wasn't giving you the airflow needed, the blue clutch mod probly wasn't going to either. From reading your posts since you had the new blower fan put in, it sounds like you might have a slow leak too.......
Oh oh, start another AC thread!:D
Don't give up!
How about a list of what has been done already.
Aux. fan mod for AC
The AC in my 92 did the same. Worked well when moving, but when still or waiting in a drive-thru it didn't and engine temp's went up to about 85% on the C H meter. After changing radiators, reworking AC unit completely with 134 then back to R12 still didn't cut it. I saw KliersLC post on an aux. fan modification and decided to try that route. I purchased my 12" electric fan out of a Toyota Tercel at the Pull a Part for $ 15.00. Fits perfectly with no existing modifications except for mounting brackets and looks factory. Then I bought a 30 amp relay and extra fuse block to use with my Helas also. Taped the relay into the AC power. Anyway, Its 101 in OKC today and I can leave it parked for at least 45 minutes and the AC freezes me out and the engine runs at 45% on the C H meter. FYI, fan clutch appears to be original and works good, probably not as good as a Blue one; however, I'm always looking for ways to save or add power to my 3FE. Problem definitely fixed. Parts about $ 30.00 labor 3.5 hours. Pics to follow if requested. Haven't taken any yet.
96
Just got back from CO and my AC did great. I had my mechanic check it out before and he said it was blowing 38 degrees. Guess I got lucky. I do have the blue clutch fan, had the radiator flushed 5K miles ago, new water pump, etc.
Grouseman
