Wanted 98-02 LX470 NON-NAV CLIMATE CONTROL BEZEL/PANEL WITH PIGTAILS
Status
Not open for further replies.
Denver, CO
Seeking this item for a nav delete. Will pay market price!
still in need?
I've got a 100 series setup from a 1998
I'll try and get some pics on Sunday
still in need?
Also worth noting I do not have rear heat so based on my knowledge of the nav delete I can't use a bezel that has a rear heat hi/lo button.
both of these are from 1998's
neither of them had rear a/c
pigtails will have 6+"'s
Yours does have rear heat it also has rear a/c so it’s just an in off I have both right now and need to go through the logic to see if the wiring can be switched. To make sure I have what I need for my swap.
So your current system is like mine with just a rear on/off button but you have a bezel that has the "rear heat hi/lo" and your trying to see if you can make it compatible? If so, good luck and let me know what you find out!
pics below
98 is first
99 is second
fan button changed between those years
the 99 had rear a/c
the 98 did not
how does someone control the rear heater under the console?
does the 98 control the rear heater under the console from the control panel?
the 99 was sold awhile ago.
pics below
98 is first
99 is second
the 99 had rear a/c
the 98 did not
Based on my reading of the "nav-delete" forum, southern-based cruisers did not come equipped with rear heat while some northern cruisers did. In mine, when I turn on the rear "fan" button, heat does not come out of the vents below the console or the vents above the left and right rear seats... Not sure if that helps or answers your question.
Wish I could have snagged the '99 bezel you sold! Ha ha.
Hey 3 Puppies, still have the LX (wood grain) unit? think this is what I need. Price?
neither are from an LX, both are from 100 series and had "wood grain"
Status
