I thought I will start my new thread of converting my cruiser to a Diesel , the 1fz is a good Engine but Diesel stands alone here what I did so far..
And that my brother is the absolute truth.There is no reason for all of Us to let the future tell the truth for as long as we keep our Faith in God we already know the truth...
Its been a while since I started my Diesel swap and glad finally its done , lot of work to it I change the color of the whole truck to factory emerald green all the door jam and black halfway top , I also added the factory tire carrier jdm plate holder , HDJ81 side trim looks and drive smooth on the highway no vibration whatsoever , I'm running on my previous 35" MTR 5.29 gear part time 4wd thanks to a short H55 5spd transmission it make a flat belly , the 12HT kick the 80series rear no problem and with the 4x4low engage its a crawler , it revs a little high I think the stock 4.10 gearing will ease up the rev other than that I'm happy with it.There is no reason for all of Us to let the future tell the truth for as long as we keep our Faith in God we already know the truth...
What are you talking about and what does this have to do with converting an 80 series to a diesel 12H-T?
I think it is response to my signature block...What are you talking about and what does this have to do with converting an 80 series to a diesel 12H-T?
How is the long term report on this conversion? Any issues with running the higher boost, and more fuel? Are the engine and transmission handling the weight of the 80 well?Hi guy's just want to update my diesel conversion its been a while without any issue except the damn oil pressure Gauge not working , is there any ground wire other than the two wire that connect to oil pressure sending unit , I have oil pressure but there's no reading on my dash , but I'm surprise with the power of the 12ht under the bonnet of my LX450 is not that far off compare to the 1fz , one time I was going 95mph on the freeway and she still pushing but didn"t want to push even more , my speedometer is not accurate due to a 35 inch tire and stock 4:10 gear maybe its faster than what it show's on my speedometer but its so stupid in my part to go Fast like that on a big truck but never do it again , I'm going to install a turbo inter cooler , open up the injector and run it 12 to 15 psi boost hopefully this will add more power and torque .
