‘97 FJ80 Suspension Issues
pwb
SoCal
My a noobie and it seems this forum is oriented to a few more folks with grease under their nails and skinned knuckles...
I’m looking for your experience and insight. i imagine this topic has been addressed before on this page but i’m likely missing some ‘keywords’ or context in my search
Have a '97 FJ80 (210,000 miles, i've owned in a little over two years, its a daily driver) with on going suspension issues. Stock set-up, rims, tires, height. Initially, a 'death wobble' was at least part of the problem, symptoms included; hit a dip unevenly, at highway speed, incurs fairly violent shimmy and erratic handling with lots of vibration coming thru the steering wheel. New heavy-duty Monroe shocks reduced symptoms but perhaps only 10-20% and that improvement seemed to deteriorate. Front end was entirely re-built ( tie rods, draglink ends, control arm bushings knuckle seals, steering dampener, $2800...) improvement noted in that steering is tight, responsive, un-even dips result in no vibration or shimmy thru the steering wheel. However, un-even dips do result in a dramatic right -left rolling action that takes 2-4 'cycles' to settle down. Steering action remains good, steering is not 'fighting me'. Shocks still appear and act 'normal', no extra bounce or leaking.
Back-end gets rebuilt (trailer arm bushings, 12-14 of them? another $900-$1000). Again some initial improvement but that 'improvement' seemed to deteriorate over the following weeks. The on-going, side-to-side pitching continues with these un-even road impacts. Again highway speeds, 60-75 mph)
Got guys recommending new gas-filled shocks, other suggesting additional installation of torsion bars, some suspect coil springs are shot...
Anxious to hear what my 'community' has to say...
My thanks in advance.
-pwb
1) check your nuts
2) lube your shafts
3) check to make sure you don't have dry balls.
So did the change the Panard bushings, also buy better shocks also how old are you tires ( find the date code and tell me) and what pressure are you running and what kind of parts did they change OEM or after market
The nuts are on the bottom of the steering arms on both sides these must be torqued to 71 lb-ft and you need to make sure the arm is fully seated.
Grease your driveshafts and tie rod ends if they have a zerk.
Make sure your knuckle balls are properly filled with moly grade grease.
Make sure you wheel bearings are properly adjusted to 30 lb-ft and no play.
When they rebuilt the front end did they install new trunnion bearings? If not, I'll bet this is the culprit.
  • Like
Reactions: pwb
You don't need special super duper shocks.
Can you do any of the work yourself? It gets expensive chasing these things.
  • Like
Reactions: pwb
Thanks for your response. There is no reference on the receipt or my recollection of any work on ‘Panard bushings’ i’ll inquire if they are using a different name for these bushings or it didn’t get done. The tires are Michelins, they were on it when i bought it. They appear to be a set but only one includes the date code (14-08), so yes likely 11 years old...
There was still 30-35% tread when this started, so i was reluctant on tire swap. Now we’re down to 10-15% so i’m game to replace ‘em. Pressure is normally 40-42 on the front and 45-48 on the rears.
Yeah the old tires are not helping, don't go Paul Walker on us get new tires, that is probably your issue
  • Like
Reactions: pwb
Thank you for your input and response. Yes, i’ agree, i fell into the hands of ‘more than amateurs but somethin short of knowledgeable professionals’. Finally ($3700 dollars later) swapped out the old tires (Michellins but made in 2010) for new BFG with a ‘stiffer sidewall’ and all seems to be well. Again my thanks!
Ask Paul Walker about 9 year old tires :oops:. , Tires have a certain life and when they reach it you feel it, I am glad you solved it.:flipoff2:
Be sure and observe the inflation guidance on the new tires. The Michelins (if like the stock tires) have a relatively low PSI max. The BFG is likely much higher, but how much of that extra PSI range you need is based on how the truck is loaded, the road you're on, and your comfort preference vs economy needs.
  • Like
Reactions: pwb
