'97 exhaust replacement - Toyota flanges
Roanoke, VA
OK, so here's my dilemma. I'm replacing my exhaust from the y pipe back. Long story but a typical one - exhaust is a patchwork of PO's work/repairs and OEM, cats clogged while back and were removed...etc., etc. It's time for new. Not paying the ridiculous prices for OEM everything - especially when this vehicle is still on the tentative list for an engine swap sometime in the future...so, below is the plan:
Y-pipe: magnaflow
2nd cat: magnaflow
Muffler: AP exhaust - cheap but as long as it works I'm OK with shortened lifespan
02 sensors: Denso
Gaskets and hardware: Toyota
Now we get to the problem:
I have a SLEE rear bumper, which is great - but I don't want to order an OEM tailpipe just to have it dangle way down below my bumper and get ripped off at some point. So, I've been looking for some aftermarket exhaust flanges that match the Toyota styles ones. That would allow me to fab my own tailpipe but still have it bolt up to the muffler section. Problem is I can only find flat flanges with the two bolt pattern. Looks like the Toyota ones have a pocket machined into them to hold the round Toyota gaskets. Am I right about this? Anybody know who sells flanges like that or should I just hack that one off and use a v-band?
is ur muffler currently welded to the rear catalytic converter? just curious since I checked mine today when I'm planning to swap in the muffler with a new one and noticed that they seem welded together. I wonder if that's from factory and this is an original.
From the factory the rear cat is it's own piece. If it's welded to the muffler section then someone was in there and built what's on your truck. Not factory.
Yes, factory cats are bolted together via flanges and the rear cat is then bolted to the muffler section in the same way.
Still no luck finding factory style flanges. Worst case scenario the union between the muffler section and tailpipe will use a different style flange and seal - was trying to go 100% Toyota on the hardware and gaskets though.
Y-pipe: magnaflow
2nd cat: magnaflow
02 sensors: Denso
Old thread with some helpful new information for anybody looking for Toyota factory style exhaust flanges, Nobody in the aftermarket world makes these flanges, if you need some you'll need to cut them off of a truck that's being parted out, use your old ones, or make your own set,
In the case of making your own set you'll need access to a machine shop to make them, That's due the the counter bore in the face of the flange that Toyota uses to hold/locate the gasket,
If you go to post 25 in the thread i linked to below it tells you the problems you'll face making your own set of flanges, The flanges made in the post below were made for use on a 93-94 truck, But I'm sure later year trucks use the same style flange,
