97 Engine noise help
when I rebuilt my 91's engine (3fe) the machine shop turned the crank .010 under but assembled the short block with standard size rod bearings. Sounded like a diesel from the first start up. had to do the bottom end all over again 20 miles after reinstalling. Hopefully your's isn't that but it is something to keep in mind.
In Subarus ther eis the dreaded piston slap, caused by excessive piston to wall clearance. I just noticed that your engine is bored .020 over, is it possible they set the clearances too wide. Also did you use a forged piston vs. a factory replacement? they will make all sorts of noise until warmed up and over idle speed. It could also be from something outside the engine rattling away at idle. Why was the engine rebuilt in the first place, failure or upgrade. that may also have something to point us in the right direction.
eVerythngbdaz no they havent so they are going to put the engine back in and i am going to drive it and see what happens.5 months is enought i want it back.
