'97 Available Brake Upgrades?
I bought some PowerStop rotors, but directly from them, not Slee. they have regular, slotted, drilled, or both slotted and drilled.
After lengthy conversation with one of their tech guys, I ordered the drilled only. He said the slots tend to fill up easier in offroad condtion, but that the drilled ones don't, unless you're constantly burying the truck in mud.
They work fine, no problems with any warping, etc.
I also got a set of their top of the line kevlar pads, in the 100-series size. They stop the truck better than other brakes I've had on the truck.
This is a 1991 truck, but the front calipers/rotors have been upgraded to the 93 and up size. Still running the rear drums, so this braking system is not as good as the newer ones.
So, to confirm, order 80 series front discs from powerstop, and they're top of the line 100 series pads? Is it bolt on and go, or do I need to modify anything?
Chris
Chris, what year is your 80? If it's 93 and newer, it'll fit, no problem. If it's 91-92, you'll need to change the rotors/calipers/wheels (to 16").
Some folks have said they've had to file down a corner of the 100-series pads to get them to fit into the 93 and up 80-series calipers, but I've never had a problem. They slipped right in.
Very good...do I need to get front and rear's or just fronts?
Chris
Since I've got rear drums on my old truck, I haven't followed any disc brake upgrade to the rears, so I don't know. I don't think I've heard of any, though.
I think the later models have discs in the rear too...Anybody know for sure?
Chris
yes, that's a certainty. All US-market 93 and newer 80-series have 4-wheel disc brakes. Probably other markets as well.
However, I'm not sure there is an easy upgrade to the rears, as there is to the fronts.
