will this fit my 96 FZJ ? Toyota Land Cruiser 1KD Turbo Diesel Engine & 4x4 Automatic Trans JDM FJCruise
Thank you. I was looking around found that one cheap. I looked harder and found a 1HZ and a turbo kit but its in the land down under. That one will bolt right up. Its from a FJ75. Im in Wisconsin. I will look harder. Thank you againWill it fit? Yes, it's smaller than what's in there now.
Will it bolt in? No, the 1KD was never used in an 80-series application. Mounts and transmission are different, likely lot of custom work needed to make it work.
Do you want it? Probably Not, it makes less HP and torque than a stock 1fz unless it's a hopped up version. It's a good motor, but its designed for lighter vehicles than the 80 series.
If you want to do a toyota diesel swap into your 80 series, the 1HD-T or 1HD-FT are the motors you're looking for.
