Hi, as I'm searching and reading through about replacing a motor, I found that a 94 cannot be swapped into the later models because of small changes due to OBD II. But can the reverse be done, the later motors swap into a 94 without issue? Or is it the same problem?
I own a 94 and may need a new motor. Thanks again.
