95 4Runner just dies while driving - no apparent reason
First of all, thank you to everyone for taking the time to read and (hopefully) respond. Basically, what happens is this: I'm driving my rig, and all of a sudden, the RPMs drop to 0, then I coast for a little while with nothing happening, then the engine dies. Most times, once I sit on the side of the road for a bit, I can crank on the starter for awhile and it starts right back up. I have replaced the fuel filter so far, and I have put a bunch of fuel injector cleaner in with the past couple tanks of gas. Neither has helped. Any ideas please?
I appreciate your time.
-W
feel your pain
I had the same problem with an 86 mazda i had. I was able to put it in neutral, turn off the ignition and coast for a while then switch the ignition back on put it in gear and it would come to life. That worked for a while then I ended up doing the same as you, pulling over and waiting a while.
Suspect the ignition module. It's housed in the distributor and if it's faulty you'll have to replace the whole distributor. But I would start your checks there. If you don't already have it download the 4runner service manual and troubleshoot the distributor with your multimeter.
Could also be vapor lock in the fuel system. How is the fuel pressure at the engine? You could also try getting gas from a different gas station for awhile. A higher water content gas will make some engines vapor lock. It boils in the fuel line at a lower temperature than gas does. An Escort GT I had had marginal fuel pressure, some under hood insulation that was blocking airflow, and was burning a bit on the lean side. The combination meant that moderate to high water content gas would vapor lock it on 95+F days. I got a higher pressure fuel pump, and removed the under hood insulation. I kept the lean burning as I liked getting an extra few MPG.:hillbilly:
Also look for other things that may be adding a bit of extra heat under hood.
