94 to 95 changes
San Jose, CA
Hello,
I have been looking at strictly 96 - 97's for a while with diff lockers... No luck for any at a decent price. Then I opened it up to 95's thinking no full OBDII compliance is ok too. Still no luck. So now, I'm looking at 94's and wanted to get everyone's opinion on if the difference is considerable enough to try to be patient and just look at 95 - 97's only.
From what I've read, here are the big items.
- 95's and on have airbags. True you don't know what the life of these things are and if they still operate nominally but I think having it there gives me another ounce of safety
- Tranny changed from A442F to A343F. How big an approvement was this?
If theres anything else I am missing thats worth considering when looking at 94's please let me know.
Thanks.
'94 ODB readers are WAY cheaper than 95+. I think its around 2cents....... paper clip :lol: (dont tell my boss, I steal them from work when I need to pull a code)
With that said I love my 94 regardless.
It depends on what you're looking for. All 80s are awesome in their own way.
91-95 require a 2 cent paperclip to read OBD codes, but they are kinda vague and difficult to figure out.
96-97 require a [sometimes] expensive code reader, but the codes are easy to read and figure out.
Some 95's are OBDII compliant, I've come across one or two.
'95's had electric controls on the seat... plastic clips will haunt your dreams
'95's had a MAF, better metering and easier to supercharge.
'95's did away with the PAIR stuff that the '94's had. (more space)
'95's had the uglyish square dashboard that makes it easier to do a CDL button or radio swap.
'94's had the better transmission, especially if you lived in colder climates and needed extra warmth...
'94's had the LARGE CAT converter with both 02 sensors on top of the entry pipes that are hard to get to.
'94's had the better radiator
'94's had the cooler looking grill.
I had the same dilemma as you for awhile but the only real advantages I could find for going with 97's were obd2 and a headliner that can be redone. I owned a 93 for 265k and never had any issues with it so I just went ahead and got a 94. I am happy to have spent several thousand less.
thanks
1993-1994
■Introduction of 16" wheels.
■Rear axle changes to full floater with disk brakes when equipped with ABS
■Also gets viscous coupling HF2AV transfer case versus
non-viscous HF2A transfer case for drum braked 80's (and fj80's)
■Introduction of 4.5l 24 valve motor.
■Front and Rear factory lockers become an option.
■Automatic transmission - Electronic Controlled A442Fwith mechanical lockup converter
■Somewhere in 1993 the AC system changed from R12 to R134. With the R12 systems the dryer unit was in front of the battery and with the R134 it moved to behind the bumper. Might have been in 1993
■The thickness of the drive plates on the front hubs were increased after April 1994 (build date). The new drive flange number is 43421-60040 and the old one is 43421-60022. This is important since certain after-market birfield joints were based on the earlier birfield. If you try to install an earlier birfield into a later truck, you will not be able to install the circlip on the end of the axle shaft.
■Supercharger systems now available for 1993-1994 models.
■Front ABS Lines are routed on the front control arm.
■Radiator is a 3 row brass core.
1995-1997
■1996 saw the introduction of the Lexus LX450 Model.
■Exhaust system changed from side by side catalytic converters to in-line converters. The exhaust also routes below the frame rail just behind the catalytic converters to avoid excessive heat on the passenger floor-boards.
■Front grill changed from the word TOYOTA written across the front to the new Toyota symbol.
■Headlight mounts are different from 1991-1994 vs. 1995-1997 and will not interchange.
■Redesigned dash board with airbags as standard equipment.
■Headliner changed to two piece molded units.
■Emission system on engine changes. Changed from a Mass Air Pressure meter to a Mass Air Flow meter. Certain plumbing was also removed.
■Supercharger & Turbo systems available for 1995-1997 models.
■ECU updates and truck became voluntary OBD-II compatible. Fully compatible in 1996 models.
■Wheel Lug nuts change from conical to washer type.
■Airbags become standard
■Automatic transmission changes to the A343F. Some 95's were produced with the A442F. The transmission type is printed on the label on the driver door.
■1997 saw the introduction of the 40th Anniversary editions as well as the Collectors Series.
■1997 the rear swaybar brackets that attach the bar to the frame were changed from a plate side that attached to the side of the frame to a bracket style that attached to the bottom of the frame.
■ABS wires on the front were moved upward and no longer run down the front control arm.
■Radiator is a 2 row aluminum
1993-1994
1995-1997
Thanks CJF. I read that on Slee as well. Problem is being a mechanical dummy, I don't know what the changes really translate into. The only thing I that popped out to me was the airbags not being present in the 94.
How do airbags work out for you when you are on the trail?
I've owned an 94 and now I have a 96. I personally liked the grill of the 94 better and wish I could swap my 96 grill out. The absence of airbags didn't bother me in the slightest in a 6000 lb vehicle. I would base my purchase decision on mileage, maintenance, price, and lockers. I would buy another 94 in a heart beat if I were in the market and I found a good one. Side note, I have the dreaded P401 insufficient EGR flow CEL code on my 96, this is quite a common problem that the OBD I guys don't have to deal with.
I too like the 93-94 dash better than the later ones. Love my 94. No CELs to dick with.
True, they don't get the P401 code. :D
They just get two different EGR codes to deal with. :doh:
(And every bit as common.)
Most of the above changes don't really translate into much real world differences. Some are cosmetic, some are mechanical and some are safety.
If you want airbags for whatever reason you're going with a 95-97. the 80's with 4wheel discs have full floater rear axles which are nice and disc brakes in the rear help with stopping distance.
All FZJ80's 93-97 will drive the same, handle the same and for the most part look the same other than a different dash and body facia for 95-97. Trannys for all years are very reliable.
Decide if you want airbags then go and find the cleanest, low mileage 80 you can at the best price. The 91-92 80 series do have a very different engine in them. Drive as many as you can and if you have any questions post them on MUD
Good luck!!!
Pete
Hi Pete,
Did this change happen in 93? From Slee, it reads this:
Does that mean it was an option? Just trying to find out when the 80's had 4 wheel discs with ABS
Thanks.
Hi Pete,
Thanks.
The 93,94 models had 4-wheel discs and ABS as an option. I believe in 95-97 this became standard. In the 93,94 models ,ABS always came with 4-wheel discs and full floater rear end.
