94 OBDI diagnostics question
Got a check engine light in my 94. Followed the paper clip code directions but getting nothing. When the directions say turn o/d on, does that mean overdrive? When my overdrive is on, I don't see a light. I have an overdrive off light, but not an overdrive on light.
What light is supposed to flash to give the code? I don't have any flashing lights on the instrument panel with E1 and TT terminals connected with a paperclip.
TT? Thought it was E1 and TE1. Anyway, I just jumpered them, turn the key counted the CEL light flashes on in instrument panel.
You're right. I found a second set of directions on here with E1 and TE1, not TT. Got code 71.
I'll double check the original place I looked for directions to make sure I didn't misread that initial TT.
I did misread the initial directions. They were for transmission codes, not engine codes.
Ah.
So 71, off to the EGR troubleshooting land IIRC. Mine was solved easily with a new egr modulator. ~$60 from CDan I believe.
