94 LC Plenum Vacuum Line help
Jamestown, NC
So I removed the plenum to change the VSV on my truck and replace the vacuum lines. Need some assitance as to what goes on the metal port circled in yellow in the picture below. The green circle is the vacuum line from EGR so it is supposed to be unhooked at the moment. Any help is appreciated.
rpzrSE.jpg" alt="rpzrSE.jpg">
Pretty sure that is connected to tee which is connected to the vapor canister. The FSM is your surest bet for precise info on issues like this where this only right and wrong.
Took a look at mine and my earlier suggestion is wrong.
VSV for PAIR
There should be a routing diagram for the vacuum lines stuck on the underside of your hood, Driver's front corner. If it's not there, let me know and I'll send you a copy of mine. Or someone else here will...
This is NLA, so we need to petition @NLXTACY to put this on his list ;)
There should be two ports. They should connect to the vacuum hardline plate assy.
Actually, its not out of the VSV for PAIR solenoid. It looks like it in the picture but that is already hooked up (black hose coming off of it right at the top of the yellow circle and 2 blue silicone lines coming off the other end). The port I have circled is actually a metal port that goes underneath (really overtop when mounted in the car) of both the VSV valves and faces downward (towards the ground when in the truck).
Well, OK, use the diagrams then.
You never said whether you have the sticker or not:
Yeah, not seeing it on the diagram which is pretty tough to decipher.....thanks for the help though!
Solid lines are the wires. Double lines close together are vacuum hoses. Double lines farther apart are vacuum hardlines. Double lines really far apart are the air intake chamber. Shaded double lines are fuel.
The sticker has a legend. Everything inside the dashed line is either on or under the air intake chamber.
