94 LC got stranded, fuel system issue.
May
Los Angeles, CA
Hi Folks,
94 LC 237,000 miles.
Got towed on a flatbed back home.
At start truck will run for a second then immediately die right after.
Verified spark with timing light.
Checked all fuses > passed.
Checked all the relays: EFI, CO(circuit opening), FP(fuel pump) > passed.
Checked FP resistor > passed.
Check engine light on when keys on.
New fuel filter and fuel pump within last few months.
Just replaced efi main relay and fusible links(my spares).
Still cleaned the contacts on the COR and FPR.
There was a thin coat of black stuff on each one.
Sanded them clean.
Opened ECM, no burnt parts.
Apply 12v to pin3 of FPR socket > FP runs
Jump pin 3 and 5 of FPR socket > engine won't run
Apply 12v direct from battery to the jumper between pin 3 and 5 of FPR socket > engine runs fine.
Reinstalled FPR > applied 12v to pin 1 of COR > FPR clicks and hear FP run. Engine runs when started.
With COR and FPR installed jumpered efi relay 2/4 engine won't run.
With efi jumpers still in place removed COR relay then jumpered cor socket pins 1/2 engine runs great!
Decided to measure voltage between efi 1/3 and get 12.3 volts while engine is running so decided to reinstall efi relay.
Engine now runs.
So EFI and FPR installed with COR socket jumpered at 1 /2 engine is running.
If cor is re-installed engine dies right away.
efi relay pin 1 to ground is continuous
efi relay pin 2 to eb1 is continuous
efi relay pin 3 to eb1 is continuous
efi relay pin 4 to eb1 to cor pin 2 is continuous, 12v
cor pin 6 to ground is continuous
cor pin 4 to vaf is continuous and vaf tested ok.
However COR pin 3 to neutral switch haven't tried yet.
Started engine, measured COR pin 3/6, it jumps to 9 volts then instantly goes to 0.
I think those are the pins that needs to activate the relay to keep pins 1 and 2 open if I'm not mistaken.
Measured 2/4 and got 0 volts as well.
So far I'm leaning towards the pin 3 route, ECU, and the COR remotely
The COR only bec the resistance measurement seems a little high.
COR pin 3/6 = 26 ohms, pin 2/4 = 147 ohms.
Any help will be greatly appreciated.
Thanks.
Seeing as you've checked most of the possible causes of a non start with no luck, If you have a back up ECM for your truck, you might want to give that a try.
Guess it's a good thing to have a backup ECM. Still have the glove box removed so I can check some pins. Just really exhausted been troubleshooting for a week whenever I get a chance. Don't have any experience checking the voltage on the ecm. So just insert a needle in the back where the cable goes into the terminal? Thanks.
Update:
I won't have any funds to buy a used ECM for now so did some more checking for the time being.
Since I am getting at least 9v but very briefly from the pin 3 route(neutral position switch), I decided to investigate why I'm not getting any voltage from COR pin 4(VAF) when starting the car.
VAF pins 1 and 2 turns on the coil for the COR.
Unplugged car battery cable.
Connected COR pin 4 to multimeter(set to voltage) to small 12V battery to 3 different ECU pins connected to the VAF harness)
COR pin 4 to ECU pin 24(E1)= .02V
COR pin 4 to ECU pin 16(E11)= .01V
COR pin 4 to ECU pin 13(E01)= .01V
12V through the VAF switch should turn on the switch but looks like it's not.
VAF harness pin 1 is grounded
To make sure I tested the voltage from COR pin 4 to VAF harness pin 2 = get 12v.
On the opposite side tested voltage from ECU harness pin 24 to VAF harness pin 1 = get 12v.
So voltage is reaching the VAF switch on either side but not turning on.
Actually I'm not sure if you need to have the harness plugged in to the VAF to interact with the ECU to make the switch turn on.
Curious I removed the top of the VAF and here is what I saw.
Pin 1 is that long metal on the left and pin 2 looks like that small angle iron piece.
The metal that comes out of pin 2 is not in the same plane as pin 1.
Not by much but you can definitely tell they are not coplanar.
So I guess if the switch closes they won't be contacting very well.
Do I bend pin 2 closer to the long looking pin 1 metal and on the same plane?
Looks like pin is connected to an armature that moves in an arc which I assume connect pins 1 and 2 eventually to turn on the COR coil.
Any VAF experts out there?
Appreciate any inputs you have.
Thanks
Pics of other vaf on the internet shows pin 2 as perfectly parallel with pin 3 which shows that it got bent for some reason.
I'll turn on the engine without the COR and see how far pin 1 gets close to pin 2
I'll adjust the pin based on what I see.
Not sure if leaving top of the vaf open while engine is running is a good idea.
Maybe put lexan glass on top, lol.
Not sure about the integrity of the pin if I bend it back to its original shape.
It might get softer and loose its tension thus leaving me stranded again somewhere.
Might just replace it and not have to worry about it
For now I'll bend it and if the truck starts with COR installed then at least I found the problem.
Will try when I get home from work. Hope my hunch works.
Will update you guys later.
Thanks.
You didn't pull out the two screws and yank out the wiring harness did you?
If so, that's your problem.......
Yeah baby!!!!!!
Cost $0.00
Tool: Screwdriver
Time: 10 days
You can actually run it with the top off.
Took a video before and after.
Will post soon.
If it wasn't for everyone's prior experience and posting here this would have been time consuming and a headache to fix.
Thanks!!!!!
Some afterthoughts:
I checked the bottom of the engine fuse block all the wires look good.
Be careful opening the FPR I broke a small section of it. The COR was easier to open for some reason. Interestingly, when you apply 12v to Cor pin 3 the starter turns on.
I have no idea how in the world pin 2 bent up and away. Just boggles me. The pins on the right of it are shorter. The armature doesn't even touch pin 2 unless it sprung out of it's socket and grabbed the pin on it's way back clockwise. The long metal for pin 1 is very thin spring steel compared to pin 2’s thick stronger piece. With power applied to pins 1 and 2 with top open and harness disconnected it won't turn on the switch. I guess you have to have the harness connected with keys to either run or start.
The silicone used for the top cover of the vaf is one good seal. Make sure you clean up all that silicone so it won't fall in the housing when you eagerly lift the cover. The cover sits on a few ledges about ¼” from the top.
The initial vaf test I did was strictly for the resistance measurements of the other pins and thought that it might give me a clue to the overall condition of the vaf but didn't know that what I really needed to check were the pins on the very left of it. Since the measurements turned out ok it led me to believe that something must be wrong with the ECM.
My backup COR arrived from ebay so I tested it. The coil through pins 3/6 activates the relay around 5V.
The coil through pins 2/4 activates the relay around 9V. Interesting.
My Efi relay is not the same as the cor relay but read that others are. So when I was looking for the same relay in the kick panel initially I had some trouble.
Daughter said “...so we could have spent 10 days in the desert!”. Ouch.
