94 LC Code 24 and 31
Let my start that by saying I have been searching the forum like a maniac along with Google on information regarding the VAF. I have the FSM which defines the Code and System as follows:
Code 24-Intake Air Temp Sensor Signal
Code 31-Volume Air Flow Meter Signal
I received the 2 codes in both normal and test mode. Of course both codes indicate a problem with the VAF. I tested the VAF using an Ohm meter as per the FSM. All three of the readings I tested appeared to be within spec. Of course, I visually examined the connections points on VAF and connector. Made sure nothing was wet, corroded, and nothing missing. I even read the post about VAF and lessons learned. So, I have not removed the gasket cover or touched the screws at the connection point. Another interesting fact is I ordered a used 1994 VAF from someone on IH8Mud. I swapped the VAF with mine disconnected the negative battery cable to clear codes from memory. Drove the truck and couple days later I notice a strong hesitation upon initial acceleration (This is the reoccuring symptom). Checked for codes and the same 24 and 31. Checked 2nd VAF as per FSM and within spec ( WT:censor:). Is this test very accurate?? I will note I bought the VAF for a whopping $75.00. The person I bought it from said it came of a 93 with about 171,000 miles. Any feedback would be great on this. I am really stumped and don’t know if should bite the bullet and by a new one from Mr. T for 600.00. Truck has 170,000 miles. I have just completed new spark plugs, air filter, distributor cap and rotor. Staring to reach Albert Einstein’s definition of Insanity: doing the same thing over and over again and expecting different results.
Sincerely,
Chris
Bump on the off chance you ever sorted this out.
I have code 24 (1994 fzj80) and stumbling at idle and under acceleration. It's like it's missing on one cylinder. I replaced the VAF with a remanufactured Denso unit about two years ago. I replaced both O2 sensors with oem about a year ago. 189,000 miles. Any ideas?
