I get some flaring between shifts under power, if I mash it say trying to get in front of a big rig while merging on the fwy it will lag, downshift and not catch the gear just redline if you hold the throttle. did my research, found out the kickdown cable was the likely culprit, went outside and found this.
the adjustment nut thing was not even near being tight and when I tightened it down I realized the cable was not connected to anything. like it was cut off at some point?
so I found 2 threads about *replacing* the cable, but no details and no follow through on a conclusion from the OP, just that its going to be messy and probably a pain in the ass.
now I know I probably won't get a good response for asking this, but can I just mate an extension onto the end of what I have there and route it like it should be? then when I drop the pan in the future I'll put in a new cable?
