'94 FZJ80 Code 25 + Rough Idle
Mt Pleasant SC
I am new so please excuse any errors in my lingo or knowledge of my truck. I am doing my best to learn in real-time via this forum and YouTube videos. My past experience was owning a 100-series that ran without fail.
Backstory:
  • I purchased the truck in January. It had an intermittent rough idle, with the idle speed around 1,000 RPM. A mechanic set the ignition timing back to the factory spec in June while I was getting some other work done.
  • The VAF (AFM?) is aftermarket Henkyo. Unclear on when this was installed as it isn't covered in any of the records shared for the vehicle when I purchased it.
  • About ten days ago I noticed a weak acceleration response and return of the rough idle, but much more intense. The check engine light came on and I got a code 25 (lean air/fuel mixture).
I am now looking to try to do as much as I can to diagnose the code 25 on my own before spending a bunch of money for a tow and a mechanic. Here is what I have tried:
  • Visual inspection of all hoses and connectors
  • Noticed the VAF connector had come partially loose due to a broken locking connector (the plastic piece that clips it in); plugged it back in firmly and gave it a spin around the block, but barely made it back due to the weak acceleration response and engine felt like it was on the verge of stalling
  • Removed the VAF and inspected as I thought maybe the solder joints had broken when the connector came loose; no obvious damage was seen (see photos)
Next steps:
  • Is there anything else in particular I should test with the VAF since I have already taken in out and opened it? Was it a mistake to open this? Photos attached.
  • Once I put it back in, I will be attempting my first smoke test to check the hoses.
  • Is there anything else I can or should test on my own for a code 25? I understand there are tests for VAFs and the 02 sensors, but it might be over my head.
Many thanks in advance for any recommendations!
- Olivia
Welcome to the site and to help with future diagnosis please go to the resources section and download the FSM and EWD for the 94. These are great resources and heck they are free.
Download the FSM and follow the test steps for getting a code 25.
Backstory:
Next steps:
- Olivia
DO NOT remove the screws that hold the female portion of the connector into the body of the unit, or attempt to remove that female connector in any way. That will likely break the soldered connections that are visible in your photos.
I know how tempting it is to just pull the those - because there they are, right there - but don't do it.
Here is the link to the '93-'94 Factory Service Manual (FSM): https://forum.ih8mud.com/resources/1994-land-cruiser-service-manual-rm360u-18sep2025.286/
It's a truly amazing tool. Download it and start learning about your truck. You can do this!
