Just purchased 94 fjz80 188k on it kinda rough kinda rusty here and there but all in all not terrible.. seems to use some oil ?? Would a pcv valve change help with this situation ? Engine runs fine plenty of power, very lite pressure at the radiator but doesn't get hot or have water in oil.. $1600 is what I paid.. thoughts opinions
First, welcome to IH8MUD. Your first official MUD salute...
Yes, a new PVC can reduce oil consumption in some cases. How much oil is it consuming and what type of driving do you do, highway, city etc.? Not to be a downer about a new purchase but the 1FZ-FE motor has a history of oil consumption related to worn valve seals and/or guides.
It's probably not a rear seal. It's probably the valve cover.
Do the following:
VC Gasket
Spark Plug tube seals
PCV Valve
PCV Grommet
Distributor O-Ring
Front Main Seal
Oil Pump seal
Oil fill cap
Power Steering Hoses (high and low pressure)
Power Steering reservoir cap
Transmission cooler hoses
Those will fix 90% of your engine oil leaks. That's a strong weekend of work once you have all the parts.
Even if you have to throw some mechanical at it and drive it for a few years. Change the body parts that need changing and use Fluid Film to stop the progression of the rust.
Sounds like a good deal. @BILT4ME has it on oil consumption fixes. If not those external sources, it will be valve seals likely. I would consider going through the cooling system soon too. All hoses, Toyota radiator cap, Toyota thermostat, Denso water pump, Gates hose for the pesky heater hose, new Toyota heater valve. If you don't do those right away consider a scanguage or ultraguage to watch that water temp. The factory guage won't warn you in time of a problem and you'll be reading headgasket threads.
