94 A442f WTF
Hafa Adai from Guam. First time thread, hope someone can help me out. I was headed home after getting some supplies for a tropical storm hit a couple of about 3-4ft puddles just about a mile home the Iceberg was at a standstill and was making a grinding/winding noise in heavy rain w/ Family. The only way it moved was when I engaged the center different lock and had to hold the button in cause it kept disengaging, but made it home,and it's my DD. Just trying to search for help while still raining. The storm is supposed to hit Sunday and they just declared it COR 2. The bad thing about it the school I work for starts classes on Monday. Prior to today the center lock switch had to be held in to engage did think to check it before cause the Wife is the primary driver. Unfortunately my truck is down waiting for a motor from a friend so hopefully someone can chime in and help a fellow cruiser lover. Already hearing the boss (Wife) talking about selling and getting something newerish. Getting frustrated you know how other half are if it works quiet if it doesn't very loud. Thanks guys and gals. Ps please help.
HELP! Forgot to ask does anyone know if there is a relay for the transmission? And if so, is it under the drivers side dash? Will a 91 -92 fit? Please HELP! My cruiser transports my family. My cruiser just reached 100082 mls. Standing by, just opened a cold one and I don't really DRINK....... SOS! all the way in Guam tropical storm alley right now....... Thanks in advance........
Your cruiser shows the tell tale signs of a stripped front drive flange.
Thanks for quick response. Wondering why would it have this problem now? Is t because the center different lock solenoid is stuck. The cruiser has no Front and rear lockers and Trans fluid is red and full. Did you mean the drive flange on the front hubs or the transfercase. If it's the front axle flange what's the best and cheapest route.thanks again.
he's talking about the flange at the one of the front wheels 93 94 had the weaker flange @ 27 spline newer models have 30 spline. it is easy to replace just 6 studs with nuts and cone washers
There was not a spline count change on the stub axle, just a length difference. Later years had more engagement.
So the part in question is 43421 in the above image.
Not too expensive to fix, either.
To Alleycats and everyone that rushe to my cruisers aid Thank you so much for the FIRST AiD . Just got done changing out the flange, now the only issue I have is that the axle is short when I pull it out to put the c clip it does not reach past the groove for the clip any suggestions,ideas,comments or experiences please let me know thank you again and again. Was the issue before I had it. I rebuilt the axle about 6 months ago.
Have you tried threading a bolt in the axle stub and pulling it out? If you have and it is still short, there are two flange thicknesses. Maybe the one you have is the thicker version and you need the thinner one.
Thanks I did it and it just barely is a hair or two, I'm thinking the PO changed it w/different year from the junkyard. I'll check on it after I get a chance. Two good things happened today the Storm passed us and I got the Iceberg running thanks to the greatest Forum w/useful knowledge that helps people w/everyday
Land Cruiser emergencies. God bless you all. Thank you again.
